I would cut it and pull it back first.Dr. Bogger wrote: there is also a foam padding on the inside on top of the firewall, is it ok to drill through that also?
basic wiring help
Dr. Bogger
well cut a + in the pad and then drill that way you can cover the wire with the pad. be sure where you drill water won`t get in. what size is the wire? to keep a trouble free leak they have a water seal connector that`s for going through fire walls then the wire goes through it. you will need a step drill bit that will drill i think 3/8 to 1'' hole that connector is pricy. or do what i did go to home depot and get a electrical connector 5/8 it has a rubber sleeve in it you will need to make the hole bigger in the sleeve for the wire to go through
