whine noise after deck install.
muddybear
Post by muddybear »
another thing. aside from the engine noise that comes throught the speakers when the car is running. theres a slight whine when the car is off. and the sound almost sounds like its coming from the deck. almost like its amplifing the sounds the deck makes. For example, with a CD in the deck and the volume at zero, and when I change tracks, it sounds almost like a record player switch to the next song.
It sounds like one of the RCA's is touching metal somewhere or such. Make sure they aren't touching anything they shouldn't or have been split open anywhere.
muddybear
Post by muddybear »
i don't think thats it since I can plug in any one RCA and it will do it. It doesn't matter which RCA I plug in, or which channel to the 4 channel amp. just one RCA into the amp and it starts making noise. i Doubt all the RCA's are bad or touching metal. also i did not have this problem with the stock deck.
Try disconecting the rca's at the headunit and leave them conected to the amp. If the noise goes away try swapping out the deck .
nightcrawlaa
Post by nightcrawlaa »
are your rca's ran on the same side of the car as your power wires(sometimes engine noise can can jump from your power wires to your rca's if they are to close)
muddybear
Post by muddybear »
well, I picked up a ground loop isolater today for $20. before I pluged it in I tried ground my amps to the same spot, double checking all my speaker wires, switching RCA's around. no change. then I pluged the Isolator into channel one and the sound is gone and everything seems to be working fine.
Except for a small prob. with the volume at zero, there is a very slight hiss coming from the tweeters, I credit this to my crappy american legacy amp. soon to be replaced with JL audio.
now I just need another Isolator for the rear.
muddybear
Post by muddybear »
oh yeah, thanks guys for all your help. I wouldn't have made it this far without reading through this forum. I'm still a newbie to this audio stuff.
No problem man, thats what we are here for.
Glad a GL Iso helped.
I was going to sugguest to run another set of RCAs to just test that...
muddybear
Post by muddybear »
is that kinda normal to have a quiet hiss coming from the tweeters at zero volume, when powering them with an amp?
