Someone give me the "idiot of the day" stamp for that one.. i deserve it.. So any recomendations for an amp & box? anyways i can get decent performance out of it without putting too much strain on the electrical system, as i don't have the money to upgrade that for now.
if it was 600watts rms go for a kicker kx 600.1 or the JBL 600.1
btw not sure if the ohms match up, those are just a couple good 600watt amps.
For box design they have all the specs needed to build a single sub sealed or ported box. I am pretty sure you have to go to the high bandwidth site though. I built my box for 2 12's using there specs. They are a slight bit over the required airspace but overall the end result is good. I built a box for a single 12 using home-drawn specs and it turned out to be near the same box, but frequencies were off. I built a box for a ten using there specs and it worked out fine also. Maybe that will help
