I think it has a lot to do with the sub as well. I tried my 10w3's sealed .75 ft^3(JL recommends .625) and didn't like the upper bass "ring" they seemed to have. Even tried polyfill to no avail. Maybe I'm just used to the higher output of my ported box. Its tuned to 28 Hz and has a lot better low end extension and seems to blend better with my front stage. Then again it may be I turned the gains up a bit more with the sealed to compensate for the lack of bass in the 40-50 Hz range.
-Fishy
Subwoofer effeciancy in relation to SQ
same exact story with quite a few lower/midrange xmax woofs... its just too hard to get good extension while maintaining a decent amount of output.Fishy wrote:I think it has a lot to do with the sub as well. I tried my 10w3's sealed .75 ft^3(JL recommends .625) and didn't like the upper bass "ring" they seemed to have. Even tried polyfill to no avail. Maybe I'm just used to the higher output of my ported box. Its tuned to 28 Hz and has a lot better low end extension and seems to blend better with my front stage. Then again it may be I turned the gains up a bit more with the sealed to compensate for the lack of bass in the 40-50 Hz range.
-Fishy
