I'm guessing i should wait?
falkenbd
Post by falkenbd »
Since the rating is RMS at 14.4 volts, and not a MAX rating, I think its safe to assume you'll get 350 watts at whatever your alternator is running at.
Set your gain the right way, maybe using a bit of overlap, make sure your wiring is installed properly and make sure you don't give yourself the opportunity to smoke the amp and everything will remain safe and sound.
Get that sub in a well designed well built box, and it'll get pretty loud with that wattage.
