Need help with this.
carolina19
Post by carolina19 »
so basically my box and amp setup is this (correct me if I'm wrong):
-3.8 cubic feet
-32 hz port tuning
-fits two 12's
-class D mono amp
-500w rms, 1200w peak
Based on this what would be the best subs for this setup? would like to spend no more than about $140 for the pair, and the cheaper the better!
Thanks for the help guyz.
NorthQuad
Post by NorthQuad »
I'm trying to find specs on those subs because we need the mounting hole diameter. Along with the rest of the specs. I don't suppose you have that info?
dave.
carolina19
Well the subs are 300w rms/ 1000w peak each, 4ohm svc, and I don't know the hole diameter or the mounting depth but I can measure both of those and let you know what those are. Let me know if there are any other specs needed.
carolina19
ok the mounting hole diameter looks to be about 11 1/8". The mounting depth of the subs that were in there is 5 1/4" but theres about 6" or a lil more actual mounting depth distance inside the box.
NorthQuad
Post by NorthQuad »
Ok, which brand and model of subwoofers were you wanting to try?
dave.
carolina19
Honestly I don't care too much. I was thinking about some 2 ohm pioneer premiers or maybe some kenwoods or Hifonics B12D4 or zeus model subs. I just want to get whatever will work with this box, hit hard as they can with money in mind, and not burn up like my worthless xplods did. But I'm open to just about anything.
scotts1000rr
Post by scotts1000rr »
That amp is only 250rms per ch. @ 2 ohms Maybe try the hifonics hfi12d4 or the crunch grp12d4
carolina19
the amp is a class D mono amp...just one channel.
carolina19
plus there aren't seperate wires for each sub, theyre wired together
scotts1000rr
whats the model # of the amp I looked up the one posted ^^^^up their.
