Amp confusion?
cool mr grinch
Purple RS
Same reason I changed to the setup I have. My amp is rated at 1100 watts RMS @ 1 ohm, I was driving 2 JL 10W6 subs each with dual 6 ohm voice coils. The best I could get was a 1.5 ohm load to yield about 800 watts. Sure it was loud, but not near what it could be without turning up the gains and damaging the amp. I switched to a single 12" Memphis MOJO with a dual 2 ohm voice coil and now can get the full potential of my amp.Bwcad1 wrote:better find a place to have it repaired soon. Good luck with that.
Your playing the amp 3 times its rated load. your maybe getting 750 watts out of a 2000 watt amp because your not at the correct load. So your solution was to turn everything up. well now your clipping your amp and your destroying your subs and amps.
cool mr grinch
i didnt want to run the setting at max, thats just what ended happening to get sound out of it, i never planned on keeping it that way. i always look for a better solution.
Ok, then I will disconnect one of my 10s which should drop the load to 1ohm readjust and see how it sounds, but my new problem is, my subs are 500 rms 1000 peak, i'll be hitting them with to much wattage, this is why i was asking the questions in my other thread about rated power at ohms, thats why i got this amp, 1300 at 2 ohms, so now i'm reading that if i run it at 2.66 ohms it will hurt the amp, so in essence i have purchased an amp to powerful for my subs.
cool mr grinch
