Question About Setting Gains?
jjohan35 wrote:What if 60 Hz is outside the recommended range of a set of speaker components? Say the components recommend 70 hz-20khz output. Should I use something a little higher than 60?
yes, use 1000
Ok Bill on to your reply.
In my car I set everything using an o-scope. I use a 0 db1000 Hz test tone and set everything in the signal chain to for 0 clipping.
Then i set my amps using a -5db tone. This gives me around 4.9 dbs more output over a 0 db tone, yet keeps my clipping below an average of .3% (unauditable)
Oh and FYI, a -10db tone will give you around a 9.4 db gain overlap, but your clipping will be around 3% (rarely audiable to most listeners).
Sure alot of us would notice it, but were far from your normal bass heads.
Schmuck
Post by Schmuck »
so should I use a 0db tone or a -3db tone for the best results? I want to avoid clipping.
In your situation stick with the 0. Without an o-scope you won't be able to tell if your decks output is clipping.
If it is, and you set the gains at a higher point (-3db) then your way more likely to clip the input and output stages on your amp.
