no output on hu
no output on hu
I have a JVC head unit that I just bought used and when I hooked it up (using an adapter from Schoch) everything works perfectly except for none of the speaker outputs are working. Any ideas??? Thanks in advance...
breakjunki
^ What they said
Also if the H/U has front preouts then you could always amp the front stage (recommended anyway).
I got a head unit here with a busted internal amp. So I know its possible.
breakjunki
I know... I was just trying to elaboratebreakjunki wrote:thatswhat I was trying to say.. If you skip all the adapters and harness and stuff and sit there with speaker in hand, go from the deck direct to a speaker.. then if you get nothing you know you have in internal problem.
breakjunki
