- What was the true rated power of this amp? What did the birthsheet say? There has been some confusion about this, as some sites say 1000 rms x 1 @ 1 ohm (not really disputed), 700 rms x 1 @ 2ohms, while others say 500 rms x 1 @ 2 ohms
- What guage wire did you use with this Amp?
If You Own a HIFONICS BX1000D Amplifier Please Look Here
Harrison486
Hey guys! What's going on? I have 2 questions for all of the HIFONICS BX1000D Amp owners out there:
The gauge of wire depends on the distance it is run. Typically 4 gauge would be enough, but for safety's sake read this section of the FAQ's:
http://www.caraudiocentral.net/forums/s ... .php?t=551
Harrison486
The only problem with bench testing is that dummy loads are expensive. There are some that are 4 ohm, but only handle up to 100 or 200 watts
I say find one that is 8 ohm or so (lower) with a higher (200-300 watt) power rating. The only thing is that it won't be as accurate for say a 1 or 2 ohm load's output (using math to find that).
I see how it is. Super-tough resistors that can take the heat!
Anyways, I think it's probably ok to wire up a series of smaller resistors. The final resistance would still be the same and the power dissipation would be shared amongst the resistors rather than having one resistor take it all.
But I'm not so sure though. Maybe KiKi can jump in to verify this....
