Ascendant Audio or Elemental Designs??
the dawg
Post by the dawg »
Looking to get a couple of 8 inch subs because of limited space in my truck. Each one will be in a small sealed box. My amp is a Hifonics BX1000D mono. Should I go with Ascendant Audio Assassins (they are single 4 ohm woofers) OR Elemental Designs 9kv.2's (they are dual 4 ohm woofers)???? -Any Recommendations- ????
i got a couple brand new 8" truck boxes at the shop you can have for 30 plus shipping......im not familiar with those subs but i think people are going to steer you towards the ascendant stuff....
swimmerdude
Post by swimmerdude »
First, what will your budget be?? This can help us determine a lot.
I would definitely go with the the Ascedant woofers over the ED woofers. The Assassin woofers seem to be a very very good sub for the price that they are.
If you can spend the money, i would take a look at TC sounds TC-1000 subs. http://www.tcsounds.com/tc1000.htm If you can get the 8" to fit, i think it will be one of the best 8" woofers out there.
the dawg
Post by the dawg »
Yea, those look like awesome subs but they are $150 a piece versus $50 a piece for the Assassins. Would rather save $$ and go with assassins but will my amp be too much power for them? the amp is rated at 700 rms @ 2 ohms x 1 --and the amp will see a 2 ohm load from the 2 subs. The subs are rated for about 150 watts rms a piece.
swimmerdude
That would be a lot of power for the assassins. The subs will never see the full 350watts that amp can produce primarily because music is dynamic. They probably can take more than 150 clean watts, but you will just have to make sure you are careful when playing them at loud volumes. You will also need to set your amp carefully so you send the subs a distortion free signal.
the dawg
Post by the dawg »
Thanks swimmerdude, I think I'll go with Ascendant Audio. They sound like a good quality sub and a price you just can't beat. I'll just have to watch my amp settings.
the dawg
Post by the dawg »
I will have the 8 inch Assassins in their own sealed box under the bucket seats in my Jeep. My question is, should they be downward firing(into the floor) or upward firing(into the seat)???
Scarrell
Post by Scarrell »
downfiring for sure..
the dawg
Post by the dawg »
Thanks, Will probly make boxes so the subs are downward firing then.
the dawg
Post by the dawg »
Alright, Got the Ascendant Audio 8 inch subs and I installed them in sealed boxes . My question is where should the settings be on my amp(Hifonics BX1000D)?? The adjustment knobs are labeled:subsonic, bass eq, low pass, phase, and level.-----???
