Sorting the good bad and ugly
Here's my initial sorting job of it. I've put my own opinions in as you may see. If there are any changes, put the category and whatnot. I still think a Questionable could be added for each.
(please visit the Good Bad and Ugly list in the FAQ section: http://www.caraudiocentral.net/forums/s ... d.php?t=32)
Mercedesbends69
Post by Mercedesbends69 »
So how are we going to do this? Is the thread going to be like a suggestion box, someone suggests a brand into a catagory and then it gets Approved/Denied? If so I have a brand or two to be added.
I say just mention it, I did leave several out. I would like this thread to have all of the modifications in it, then we can move the list to the voting booth and whatnot.
you forgot boston acoustic in the sub section I would put them in highly recommended, but my experiance was with the older pro series, not the newest stuff.
head units:
wouldn't recommend anything kenwood, panasonic, or blaupunkt if you care at all about reliability.
Sony's Moblie ES line of head units from the early 1990s were excellent units, but expensive, and rare.
Amps:
highly recommended-
Harrison Labs
pre-DEI Orion
early 90s RF (punch and power)
PPI Art series
Planet Audio is a take it or leave it thing. some love them, some don't. I'd put those in the "maybe" column. I'd also use a numeric system ranked from levels 1 through 3 or 4 instead of labeling things good or bad. then you'll get less stress about if something "sucks" or not.
Main/component speakers:
highly rec-
infinity kappa perfect
JL ZR component line
Eclipse I'd move to highly rec. they make great components.
on par with anything from infinity at least.
subs:
highly rec-
alpine type R
diamond's subs are very good.
Good-
alpine type S, E, etc under the R's
I tried to work around saying "bad" by using "avoid" but do you think I should change "good" to "reliable"?
armedforglory
Post by armedforglory »
under amplifiers, planet audio is under both questionable, and avoid, just lettin ya know!
LOL, must fix... or should I? :D
I think Planet Audio deserves its own category, even better then the best! :)
Fubar
Post by Fubar »
William from NOLA wrote: Highly Recommended
Rockford Fosgate (Power series)---move to good
Memphis Audio--- move to good
Good
JBL--high end crown series should push this into highly recommended
Questionable
Planet Audio-- atleast good... highly recommended on mypart..how many amps come with the warranty that PA's do?
Avoid
MA Audio---good
Power Acoustik---questionable
Main Speakers
Highly Recommended
Infinity (Kappa and Kappa Perfect series)-- kappa to good
Avoid
Planet Audio--i got a 6.5 yellow carbon fiber series to try out once.. and i liked them.. i think they should be questionable
Subwoofers
Highly Recommended
Kicker (CompVR series)--good--and where's the L5, L7, solo-x, & comp?
Alpine (Type-R series)---good-- and what about the x? i haven't heard em but they're not listed..
Good
Alpine (Type-S or E series)--type e should go to avoid..
Pioneer--lower models should be avoided
MB Quart--- i'd bump them up
Avoid
Planet Audio- the stroker lookalike is nice.. but everything else is marginal at best..
my "fixes"
