amp??
Here I am bringing up Xsite again.
The XAD1200 1200wrms @ 2Ohms, gets you little closer to your goal, but I still agree with the others in that... It's much more than what you need and keep in mind that even though Diamond may have said it could handle it, that doesn't mean they will warranty it if you blow it (just warning you).
Anyway, you still wanna know the price... For CAC Members Only! $339.00 plus shipping (normally I sell for 389.00 and retails at $439.00)
and here I am getting Xsite-ed... :)
thanks for all your input. i would rather just run 1kw but the tech guy at diamond said that since its would be in a 4cf box that it could actually take way more then 1500. Now one more question i am torn between a 200 amp and a 160 amp alternator, my stock is 117, would it hurt to have a bigger one then nessesary i am lost when it comes to that
Won't hurt to go with a bigger alt and it leaves room for expansion down the road without having to upgrade again :)
rick_o_connell
Just a thought on replacing the alt, you might want to check with the manufacturer to see what the limit is on your power system to see what it can handle first. Nearly doubling the factory specs (117 to over 200) could fry the cars computer, or do other damage.
I had a Crown Vic with the PI package (I believe it had a 170 amp alt, and the regular CV's had around 130) and I had a system with 2 solo-baric s15d's in it, added an extra battery in the trunk and the lights never dimmed or flickered.
Regards,
Rick
Regards,
Rick
You could run them off the head unit to start... but I'm sure you'll want to amp them down the road.
