couple of repair questions......
1) what kind of glue should I use to replace a sub dust cap, and is there anything I should be aware of when I do this 2) I have a rockford 800.1 and it wont power up, when I checked it out I found that the rem turnon lead is severed on the circut board. Can I just solder it back together? and as above is therer anthing I need to know about ding this?
Glue: Use super glue
Board: Goto Radio Shack. They have a "pen" with conductive ink. Scrape away the coatng over that trace and draw a new one on. Or you can smply put a spot of solder on it.
I have repaired circuits before by using solder or even a jumper wire from the initial connector to the first componet in the circuit.
