led's
gonna try it out with some of my little tests i have been doing. I'm planning on doing some plexi grills on my carbon fibers, they look to damn cool to cover them up, and I'm going to light them up with some led's. wanting to see if i can use some of these brighter ones yet cause the light to spread a little wider.
JC's Customs
JC's Customs
- Chris from Washington
ya you can use the wires already up at the dome light, What bulb type is your dome light? is it this type?
Then you can just make a board, that snaps in between the connectors. I made one once that way.
Here was the test one I made,
You can get those boards at radio shack, I think they were a 1.99. You'll want one with the solder pads.
i tried filing one of the leds last night. just scuffed it gently till the plastic turned white. all around the tip before it straightens out. made a huge difference in the viewing angle, yet did not seem to affect the brightness at all. where it was scuffed was glowing like the diode was right there. anyway, thought yall might want to know. now i have all kinds of ideas for leds, if yall have any good ideas for led application, post them!!
JC's Customs
JC's Customs
most LED packages will list the dispersion angle so you can see how wide the light is or at what angle it can be viewed.
just find wide angle dispersion LEDs
mA ratings don't really have as much bearing on brightness as the material the LED is made of by the way. Pay more attention to the Mcd ratings instead.
yeah radio shack is freakin expensive, but we all new that. it is handy though when you need something right away. I got a buttload of led's on the way, all kinds. Anyone have any experience with the uv's? I had a cool idea, install a board like darth is doing into my dome light with the uv leds(black light). that may be cool, no?
JC's Customs
JC's Customs
