what can i use on my kick panels?
6three6mafia6
Post by 6three6mafia6 »
i got some kodas and the speakers have a very big magnet and there kinda deep, they do not fit in my kick panels, the kick panels are too deep, i need to cut about an inch from the opening pod for the woofer to raise that speaker up, BUT when i do that there is not gona be anywere to screw it on too if you dont know what im talking about look at this > {(o)}that inner area is were the woofer is mounted(about 3/8ths) when i cut an inch off there is not gona be anywere to screw the woofer on {( )} so i need a way to make a new piece that will cover the whole 6.5 pod and ill cut it again to make the part that holds the woofer, SO does anybody know how i can do this , i guess what will stick , harden , and give me a new solid flat surface?
PLEASE HELP!!!!!! ive these kodas for about a month someone help!
Scarrell
sdfdsj
Post by Scarrell »
just make a baffle using 3/4" MDF or a little smaller if you need too. should work.
6three6mafia6
and how is this baffle supposed to stay on the kick panel?and there made out of ABS.
Scarrell
Post by Scarrell »
you cut the baffle to fit the kick panel, put it in, and put the speaker in the baffle and screw it in.
NDMstang65
Post by NDMstang65 »
so you make the baffle and fiberglass over top of it...fill it...sand it...paint it...done
6three6mafia6
OHHHHHHHHHHHHH i get you, damn now i know why you said 3/4 inch, so i can screw it , kodas here i come! :sm29:
