anyway i have 2 kicker cvr DVC both are 4ohm, and my wiring options are either 1ohm load or a 4ohm load(correct??)
and when i first got into this i thought you just matched up the ohms from amp to subs(which you usually do) but now i find out that when an amp is bridged, it halves the ohm load, so a 4ohm load will become a 2ohm load to an amp, so the amp puts out the power at 2ohms(riiiiight?)
so basically my set up won't work , and i need to get a different amp (correct?)
